Took delivery recently of a kit based on the new BMC V4C geared hub motor.
A 26" rear wheel build to be run at 48V and 20A.
Purchased from Ilia Brouk of [ Ebikes SF ].
Initially, the kit was to make use of a Lyen 12FET sensored controller but as it turned out there were problems. Controller was fine with the original V2 motor series but not with the new V4C. And, so, was exchanged for a 25A 12FET Crystalyte unit which exhibited no problems in use.
As for the first test ride?
The initial objective being to compare the V4C to my eZee kit.
With stellar results…
Increased efficiency over my eZee up to the 30% area.
A 46 km trip seeing 5.6 Ah drawn.
[ 8.2 km/Ah average ]
My body weight = 88 kgs.
A trip that included some occasional light pedalling over rolling terrain with numerous WOT tests. More than half the distance travelled being into a 20 km/h headwind. Average speed was in the 28 km/h area.
And at, again, 48V and 20A unassisted top speed was 47 km/h on flat and level terrain in the calm [ 43 km/h into the mentioned headwind ].
A 100 meter 6% grade was climbed unassisted [ WOT ] at 31 km/h.
WOT usage never seeing north of 750W.
My eZee kit, on the other hand, shoots north of 900W climbing that same grade unassisted at WOT [ 22 km/h ] while unassisted top speed is in the 40 km/h area on flat and level terrain in the calm.
Came as a complete, and hugely welcome, surprise to me that the V4C would be more efficient than my eZee given that the former is rated continuous 1,000W to 1,750W with peak in the 2,500W area while the latter is rated 500W continuous with peak in the 1,050W area.
And, so, just thought I'd make mention should anyone be interested.
The V4T, V4C, V4S series being relatively new to the market.
