Crash Machine
I got this hybrid battery from a very good friend of mine that deals in used auto parts. It's a 2005-2006 Honda Civic hybrid. It had been totalled no visible damage to the battery..Through research I found it should be a 144 volt 6.5 Ah NiMh battery. Not sure yet what to do with it.
I took it apart last night(yee haw) and was impressed how well made it was. The cells are not tabbed as i had fear but have well made screw type terminals. They are in 6 cell strings, 20 of 'em. They are 1.2v 6.5 Ah cells I believe,they look like D sized cells. Total pack voltage was only 66 volts. Each 6 cell string only read 3.3v give or take for each string. Would that kill these cells?
I found my old 6v 1 amp sla charger and found the final voltage to be 8.20v. Doing the math each cells charged voltage should be 1.4 to 1.6v. So 8.4v to 9.6v final charged voltage for each string so 8.2v should be safe I assumed.
Armed with this knowledge I hooked them up to the charger last night and charged till I saw a string reach 8.15v.. About an hour and a half.
Woke up this morning and the voltage read 7.6v and holding. I then charged the same string again till it got to the final voltage of 8.2v. Another 45 minutes so 2hrs.15mins. That's where I am at this morning. Charging a second string now and I will see what the first string holds at.
6 of these srings should give me a 48v pack. So is it hard on NiMh to sit at such a low voltage or are they salvagable? Also there's alot of stuff I have no idea what it is.. I will post more as i find out.
This is great experience for me. I start college in the fall for electrical engineering. So even if it's kinda impractical for my uses I am still going to try to build a pack from these and will report my findings.
Btw this guy is gonna keep his eye out for these for me.
