Arbol
I am looking for to build an e-bike satisfying European legal requirements, but offering decent performance.
Basically, there are three motors I know of in Europe that offer 250W "legal": the new Bafang BBS-01 in 36V 250W form, the Q85 / Q100 and I believe there is another Bafang hub 250W called SW or something similar.
What I see is folks have been trying to improve performance out of these motors by two means: either using 48V batteries / controllers which provide more voltage, or using controllers providing more amperage (and keeping the 36V batteries). Most of what I have read is regarding Q85 / Q100.
It seems the Q85 / Q100 accepts relatively happily 48V, since internals are able to cope with that. Amperage is harder: KU63 / 65 provides 12A maximum, and there have been reported problems with the usage of the KU93, providing 22A max. Some people have "soldiered the shunt", providing approximately 17A or 18A on the KU63, and that seems safe (I assume this is with 36V; with 48V, probably that would be too much for the motor, right?).
Power is voltage times amperage. But it seems increases in each component have different behaviors on the e-bikes: an increase in voltage improves both max speed and torque. An increase in amperage improves torque only.
What I would like to ask is real world experiences on improving performance on these motors, especially the Q85 / Q100, which is the one I know the most. I believe there are no reported experiences with the BBS-01 yet on this issue:
- Is an increase from 36V to 48V battery safe for the Q85 / Q100, if one keeps the KU63 unchanged? And if one soldiers the shunt on the KU63?
- Why is the improvement from KU63 to KU93 worse in reliability terms than the improvement of voltage? It is just the increase is higher (22A/12A is an increase of 1.83x; 48V/36V is an increase of 1.33x; 17A/12A is an increase of 1.42x, so the improvement by "soldiering the shunt" is similar in size terms to improvements in voltage) or that increases in amperage tend to be more unreliable in general than improvements in voltage? I ask this because I would prefer to make improvements via more amperage, since one can continue using smaller batteries, and using the relatively high continuous discharge amperage of LiFePO4 batteries. Instead, by increasing voltage, one needs more bulky batteries, but the high discharge amperage capabilities of the big LiFePO4 batteries remained underused, which is suboptimal
- Maybe this is crazy, but could one use a 24V battery with a high discharge amperage rate to keep power under reliable limits, small sized batteries and a decent torque? (granted, max speed would suffer, but I do not care much about it)
- Can anybody make a guess of which could be the best improvements for the BBS-01?
Finally:
- Which is the sweet spot?
Thanks.
Edit: if one used say a 6 FET 25A Infineon controller with a 24V battery (eg Cell_man), max power would be 600W (24*25). Of course, assuming the controller accepts a 24V battery, which is not obvious (I guess one could program the LVC). Instead, with 36V and "soldiering the shunt" of a KU63 one gets similar power, 612W (36*17). If this last combination is reliable with a Q100, couldn't it be a 24V / 25A combination also be reliable, since power is similar (even a bit lower)?
The reason for this odd combination would be that in Europe, a motor cannot help further than 25km/h. As a consequence, what matters to me is what the motor does between 0 and 25km/h, so what matters is torque. That a 36V or 48V battery could provide higher max speed is immaterial to me, since regulations do not allow me to use that increased max speed (unless a 24V cannot even reach 25km/h, I do not know that). Also, I care much more about the ability to climb hills rather than max speed: within the city, I will never use high speed (too dangerous). And for weekend trips, higher speed means simply arriving a few minutes earlier, which I do not care much. But torque means being able to go to places (slopes of say 20%) that I cannot dream of right now, without a motor (but these places exist nearby!).
Finally:
Thanks.
