hi there from Italy,
can anyone give me please a suggestion for a powerful yet easily tunable controller for a motenergy ME 1304 motor with the following specs? ( i was looking for a gen4 type 6 sevcon controller but reading some posts on this forum I had the feeeling it is a P.I.T.A. to program, and it needs a native and expensive software, if I have correctly understood)...
many many tks in adv
ciao
Marco
motor specifications:
High efficient permanent magnet brushless DC motor. Designed for long life. No brush maintenance. The motor has peak efficiency of 93 % at voltages between 24 - 96 VDC continuous current of 250 amps at 96 VDC. This is a 3-phase, Y-connected Permanent Magnet Synchronous Motor with an axial air gap.
Continuous Power (kW): 22,32
Peak Power (kW): 51,6
Rated Continuous Current (A): 250
Peak Current for 1 min (A): 650
Voltage Controller max (V): 96
Peak Stall Torque (Nm): 88
Rated Torque (Nm): 33
Efficiency (%): 93
Turns per Phase 20
Resistance L-L (ohm): 0,0063
Inductance @ 1kHz (mH): 0,066
Inductance @ 120 Hz (mH):
Voltage Constant (V/RPM):
Torque Constant (Nm/A):
RMP max (1/min): 6500
Weight (kg): 16,8
Temperature Sensor: KTY84-130
Encoder Type: Sine/Cosine
ciao
Marco
Efficiency (%): 93
Turns per Phase 20
Weight (kg): 16,8
