Copenhagen Wheel Charger Wanted
BikeDan16
10 µW
Tucson
I believe my Copenhagen Wheel is working, but the charger seems to not be. I am in the market for a new/used one.
I need a charger as well for a bike given to me.
Let me know if you’ve found a place to purchase one.
Mine is a 2 pin
Unless your battery uses a communication signal, you can use any generic charger designed for your nominal voltage (36V, 48V, 72V etc..), chemistry (Lithium Ion, LifeP04, Lead Acid) and max charge rate (2Amp, 4Amp etc...). Then you just have to match the connector and confirm polarity. You can buy them from anywhere like Aliexpress, eBay, Amazon etc... There are also more robust chargers like the Cycle Satiator.
If you're still on the lookout, could refer someone i got the 2pin charger from.
