DrkAngel
1 GW
Everything, except for the motor, is likely to be identical.jk1 said:What is the difference between the 200w and 450 currie ezip bikes ? i have a 200w version and am wondering what is needed to make it 450w ? do i need the new xyd16 motor , is the controller the same or do i also need to upgrade that ?
Just swap the motor.
Will work fine ... but ...
Check the controller, if labeled as 30-35A rated then all set.
If 20-25A, or less, then you will benefit from a larger controller.
450w motor supplies 225% the torque of the 200w motor.
Recommend:
eZip-iZip 20mph upgrade $20
