The CA is not going to materially improve your efficiency - it does lots of things, but that's not one of them.tomjasz said:I'd like to be as efficient as possible for battery use. Any suggestions for a staring point? Are the default settings OK to start?
It can improve my understanding of the efficiencies. That's a huge feature. Thanks, that helped a lot. Maybe the most frustrating part is that, "my eyes are bigger than my stomach.." I want to move faster than the old brain will work. The unit I sold is in the hands of a youngster and he's already way out ahead of me in understanding the functions. Sadly he's half a continent away.teklektik said:The CA is not going to materially improve your efficiency - it does lots of things, but that's not one of them.
Hooking a 5v brake into the CA will override the controller brake function. ie. the CA will monitor the brake signal, not the controller. When the CA see's brake it cuts throttle to controller.BoomerChomsi said:Hello all,
I have bought a new controller.
I would like to use brake feature, but I have one problem.
The controller brake will only work if input is 12V (high).
CAv3 brake input is 5V?
Thank you!
You did not specify, but presumably you have a CA-DP hookup and are using the hall signal for speed sensing. If your CA PCB is now dry (normally happens because of venting through bottom openings), then you likely have a wet CA-DP connector. Unplug the CA and dry the connector (hair dryer or leave open overnight). Do not attempt to 'clean' the contacts with anything abrasive. Plug and unplug the connector a few times which should restore the hall connection.John Bozi said:Only thing that has happened recently that may have changed something is I rode through heavy rain. I had condensation under the screen on the next ride, but has gone now.
My speed reading doesn't work for about a third of the ride and the kms travelled as a result are incorrect too. It comes on and off for a while and then towards the end of the ride it kept working.
Any ideas what's happened?
I'm not sure if there is a question in there...John Bozi said:Note I run two motors, one controller is connected to the ca gets everything right except AHs used. I used to think that the ca calculated AHs from voltage but soon learnt that it doesnt because it only shows me ah used for the controller connected to the ca...
The CA expects a simple NO (normally open) switch to assert the ebrake signal by bringing the ebrake input to Gnd. There is no external 5V signal - the 5V is an incidental result of the pull-up resistor on the ebrake input line to the CA 5V supply.BoomerChomsi said:I have bought a new controller.
MrDude_1 said:The mount for the CA is tall for a scooter, I was thinking maybe there was a way to mount it lower, almost flat on the bar..
any good ideas?
Gab said:For a mid drive is it possible to hook up a hall signal wire to the PASS input wire from the CA to read motor RPM on a middrive on the CAV3 ?
Will the voltage and rpm values match ok to read direct of a hall sensor?
Never once used the switch on any PTW. It was debated to death on Modernvespa, but nonetheless, never used by me. I did add a switch to my current build, only because the shrink wrap battery had no switch, like my frame mount batts. I've got to busy of a handlebar setup to add another switch. Actually I hated the damn thing on my Vespa. I was forever bumping the switch to the off position when accessing the seat storage. Much adieu about nothing from my perspective. But I imagine for those who have the muscle memory from powered two wheelers it may be attractive. As I type I'm reminded how much I disliked it.Alan B said:I think all ebikes should have a run-kill switch near the handgrip like all motorcycles, scooters, mopeds, etc have. Then it is easy to turn the bike on, and off while keeping the hand on the grip. It is a safety issue. Putting it on the CA is not a good choice, it is too far from where the hands need to be.
cal3thousand said:MrDude_1 said:The mount for the CA is tall for a scooter, I was thinking maybe there was a way to mount it lower, almost flat on the bar..
any good ideas?
You could use one of these:
http://www.amazon.com/Minoura-Handle-Space-Grips-Small/dp/B003AI3WX6
