John in CR
100 TW
Some of us will soon be using the CA3 on dual controller rigs, and I want to make I'm not overlooking potential issues. The two controllers run a single motor, actually on alternating teeth of the same stator, so there aren't any sinc issues with exactly a 1 tooth (15°) difference in the commutation sequence between the controllers. The supply is from the same battery with main power wires together to close to the controller to avoid voltage differentials trying to flow through the common throttle, and we've had no issues running a single throttle wired to both controllers. We have the Ebikes.ca high current stand alone shunts, so the CA3 will be able to sense the current fed to both controllers.
My only question is about the yellow wire on the CA connector the Sp wire. We can only wire that to 1 controller. As long as it only senses the rpm based on the hall pulses and pole count, then we're fine. If it is used somehow to sense and regulate current, especially in the torque throttle mode, then it may be problematic, since the other controller "sees" a next magnet and get a hall pulse in between hall pulses of the 1st controller. Is this a potential problem, or does that Sp wire only sense rpm?
Anyone see any gotchas in this plan?
Also, I didn't see mention of tying an inclinometer to the CA3. I know quite a few people interested in that for anti-flip protection along with power wheelie control. I just wanted to post a reminder about that, since it's been several months since Justin and I discussed it.
John
John
