Dani
- Joined
- Jul 12, 2014
- Messages
- 40
Hi everyone,
my name is Dani, I'm 25 and I love riding bikes / anything that moves without (or close to no) effort. I come across the GNG kit and it sucked, except for the motor. Then I saw LR's kit, which is pretty awesome, but too expensive to me. Also I wanted something lighter, smaller, better and selfmade. I love being in the workshop. I know being better is pretty hard but I don't mind
I will update the development from time to time. As a student I shouldn't even have time left for this.. but I'll manage. somehow.
goals:
very light build
as small as possible
easy to build (little to no special tools)
cheap! Any penny counts
sturdy! So I can put 2kW+ on this thing
advantages over the LR/GNG Kit:
less parts (less sheets, less screws, less everything)
lighter (lasercut and bent aluminum, designed for light weight)
Easy available parts (like a bottom bracket instead of a custom made jackshaft/housing/bearing)
Let's find out if this can be done any cheaper
Sheets:
I want one sheet, one piece, which saves me costs on the Laser Cutting factory. They are pretty cheap and based in germany. The whole box (1 sheet, without any extensions/screws/..) will cost me less than 20€, more like 15€ or so.
After lasercutting I'll bend it on my yet to be built DIY-20ton-hydraulic-press like this one
Any source for cheap metal carrier within germany would be golden.
Bearing (jackshaft):
A bottom bracket should do the job. The problem is the ISIS shaft, which I can't machine a fitting sprocket/tube onto. So I looked at BBs with JSI shafts. I could make a sprocket to fit the square with my drill press and a file. Also they cost less than 15€ (FAG). I couldn't find much reviews about the one linked, but they are FAG/schaeffler made (german, high quality bearing producer) and are said to be long-lasting. We'll see. A truvativ DH isn't that much more expensive (<35€).
15€ sounds better than machining my own jackshaft/housing/bearing.
gearing:
I like to use the same setup like LR does. It has a nice gearing reduction, it is silent on the primary drive and is to some degree proven. I don't need to reinvent the wheel here. I'll buy the 90T GT2 pulley from him directly (can't find any good source), it's made of plastic, which is light and strong enough. No worries here. I also have in mind to just lasercut 3 pieces with the wanted tooth profile and screw them together.. printings will follow. Also aluminum, very light.
same gearing on the secondary side. I'll make my own big sprocket, let's see. Not sure which freewheel I'll end up with. Need to find a good source for a heavy duty freewheel that is affordable. Otherwise I'll end up with a cheap freewheel that will have a very hard time
tensioning:
first tension the secondary (right side) by turning the top screws on both sides evenly. Once the chain has enough tension, tighten the BB (top). Now use the primary tensions screw (front, single screw) to push the motor away from the jackshaft. Once tension on the belt is good, simply screw the motor to the sheets, relax the primary tension screw a little: et voila, it's done.
Disclaimer: I don't think I will go commercial with this. As of now this is a hobby for me. If you need CAD drawings or think this is suitable for you, just contact me, no problem ,
First try:
Second try:
Third try:
this is the summary of the first few posts. For development continue reading here
I still need the correct dimensions of the GNG motor. Anyone care to help out?
goals:
very light build
Sheets:
gearing:
tensioning:
First try:
Second try:
Third try:
