MitchJi
flyinmonkie said:Mitch,
Everything should be rotating in the same direction under power no matter what is powering it. The freewheels are held on by threading on in the same direction the whole thing rotates. Because the outside spins without the inside spinning in the other direction, or vise versa, it will not thread itself off. If you reverse an adapter, I the freewheel will thread itself off when driven, unless you use a left side drive freewheel. But then it won't thread on the adapter. You shouldn't have to flip an adapter over to make it work, unless I'm missing something.
FM
Hi FM,
The sprocket and FW will turn in the same direction but:
The FW sprocket drives the shaft - which forces the FW around the shaft in a clockwise direction
The shaft drives the Cog - which forces the cog around the shaft in a counter clockwise direction
