You can't go wrong with a couple of the red $5 Harbor Freight meters. The initial calibration can't be trusted to better than a few tenths of a volt, but there is an obvious adjustment pot to be seen if you take the back off. The accuracy is still not great away from the setpoint so you should calibrate near the balancing voltage. Some options are a fresh CR2032 at 2.95 volts, a 7805 regulator with ~100ma load at 5.00 volts, or http://www.national.com/mpf/LM/LM4040.html. I use two of those in series at 2.5 volts each with 5ma from 12 volt supply, so can calibrate at either 2.50 or 5.00 volts and check how far off it is at the other voltage. So far (4 meters) not more than a tenth of a volt.
