CUDAcores89
1 W
- Joined
- Aug 28, 2016
- Messages
- 51
I finished building my electric bike a couple of weeks ago, and I have been using it to commute to and from where I work for the past couple of weeks.
I actually built the battery myself out of "dead" laptop cells as many others have done. My battery is 10S5P 36v 10AH for a total of 360 watt-hour(and yes, I DID charge and discharge each individual 18650 cell to verify it's capacity was about at least 2000mah to go into the pack). I am using a cheap 250w hub motor from ebay and counter to what others have told me, it actually works really well. Also to add, the motor was sold as being 250 watts. Except I put a watt-meter on the battery to measure the draw under load and it was reporting 450 watts, almost double what the motor was specified. Now my ride to work is a poultry 2 miles, so the battery appeared to work fine. Today I decided to go for a much longer ride and really push my battery to the limits. I went on a bike ride and (with absolutely ZERO pedaling, I wanted to see how far I could go without assist) I managed to go 15 miles on the battery. I got home and my battery felt quite warm. I quickly pulled out my IR temp sensor and recorded 110 degrees F .
Now converting that to Celsius that is around 40C. Not enough for me to worry about the battery going nuclear, but high temperatures on almost all batteries is very bad for them and can shorten their lifespan quite drastically. Theoretically, the pack should be able to take this discharge since I have chosen cells whose datasheets had specified a maximum continuous discharge of 2C. Although the cells still seem to be getting quite warm. Now that I have discovered this, I have a few options:
1. I can find a way to actively cool the battery pack. I am thinking of using something like a fan, any suggestions?
2. I can double the size of the battery to 36v 20AH. I already have the cells laying around to do this (that have been charged, discharged and resistance tested) but this will double the battery weight to 10lbs.
3. I can buy new cells and assemble a pack out of proper high-drain 18650s. This is the most expensive.
4. Just not care at all. My commute is only 2 miles anyway so the batteries are not going to spend a tremendous amount of time under full load.
Any suggestions?
Any suggestions?
