A saving of about $4.40 per cell. Seems like a bad deal to me if you can't use them as packs.DAND214 said:SO WITH SHIPPING WERE LOOKING AT $20.60 A CELL, 42 cells!
Dan
Paying $7 per cell in shipping isn't exactly free.deVries said:Anyway, I think replacing a bad module for free IS much better than no warranty at all. I think you have snagged an awesome deal, *IMO*.
That's for shipping 2 modules, so a group buy or volume purchase may *possibly* be cheaper. Anyway, no one in China ships anything free to the USA, whether it's new or a replacement. At least the defective module is replaced free of charge, which is a savings of $283. Free shipping does not really exist... shipping is factored in the cost whether it's "free" (not itemized) or not. But coming from China? Get real. Be realistic. :wink:MitchJi said:Hi,
Dan
deVries said:One very positive aspect about these 7s3p modules is it appears these are made in three separate 7s strings, so it looks to be very simple to separate these into 7s1p modules by just cutting the parallel connections or wiring connecting the three 7s strings together as 7s3p.
Teh Stork said:So, I've tried to fully understand why these modules are scrapped for car use? Are there simply some welds that could fatigue and fail - or is this problem with the clamping of the cells? Could someone sum this up shortly?
A123 FAQ said:One of four automated tab welding machines in the prismatic cell manufacturing process at our Livonia, Michigan facility was incorrectly calibrated, causing a misalignment of a certain component in some prismatic cells. This defect was undetected by our standard visual and electrical inspection.
When the defective prismatic cells were subsequently compressed as part of the module assembly process, a mechanical interference was created between the misplaced component and the foil pouch which contains the cell. In certain cases, this interference breaches the foil pouch electrical insulation causing an electrical short which can cause premature failure of the battery module or pack, leading to decrease in performance and reduced battery life.
MitchJi said:Paying $7 per cell in shipping isn't exactly free.
Someone posted that his shipping cost is going to be about $140 per module, and that he will have to pay shipping on warranty replacements. It will cost him about $140 in shipping costs to get his "free" replacement. If they require him to return the bad module it would cost him about $280.deVries said:Anyway, no one in China ships anything free to the USA, whether it's new or a replacement. At least the defective module is replaced free of charge, which is a savings of $283. Free shipping does not really exist... shipping is factored in the cost whether it's "free" (not itemized) or not. But coming from China? Get real. Be realistic. :wink:
My Bad. Caused by early morning sleep deprivation.Teh Stork said:deVries said:One very positive aspect about these 7s3p modules is it appears these are made in three separate 7s strings, so it looks to be very simple to separate these into 7s1p modules by just cutting the parallel connections or wiring connecting the three 7s strings together as 7s3p.
No, judging by the picture - you could not split a 3p module intp 1p module easily. You could certainly easily split them - but saying the result would be a module would be wrong.
***EDIT: I changed this to now read: One very positive aspect about these 7s3p modules is it appears these are made in 21 cell rows, so it looks like it might *POSSIBLY* be a simple process to separate these cells using a dremel blade with vacuum. Pure speculation on my part.
mistercrash said:A guestimate on dimensions of the pack? I could fit three in my scooter. hmm...
We do not know how the wiring or connections specifically work for these modules, so it is pure speculation how to configure these modules for a specific application such as your project. I think you mentioned you are new to electric bikes, so this is a very complicated issue for a newbie to take-on, imo. You'll need to wait until others get these modules AND post the details about these modules. In the meantime keep reading other topics & threads, so you can find answers to the questions you have below. You will have to invest the time to read & learn, since there are already answers to the questions you have below that are ready to be found now on the forum.lukehutch said:These are 20Ah per cell at 3.3V, right? So in 7s3p configuration, you'd get 3.3V * 7 = 23.1V for 20Ah * 3 = 60Ah per module? So with three modules connected in parallel you'd get 23.1V, 180Ah or for three modules in series you'd get 69.3V, 60Ah?
Sorry, Off-Topic... Please post this elsewhere. :wink: There is a Scooter/Motorcycle section of ES you might want to check-out.lukehutch said:What is typical voltage and current for a motor sufficient to drive a scooter? (Want to make sure I'm doing the math right...)
deVries said:Sorry, Off-Topic... Please post this elsewhere. :wink: There is a Scooter/Motorcycle section of ES you might want to check-out.lukehutch said:What is typical voltage and current for a motor sufficient to drive a scooter? (Want to make sure I'm doing the math right...)
That post provided useful "estimate" information to this thread: Estimate of Module Dimensions 8)lukehutch said:I don't understand how somebody making a statement about mounting three of these on a scooter is not flagged as off-topic, but me asking a question about how whether that many of these cells would actually work for that purpose is flagged as off-topic, but fair enough.
NOTE: "certain component" and "undetected by our standard visual...inspection" sound like something inside the pouches rather than the tabs.A123 FAQ said:2. What is the cause?
One of four automated tab welding machines in the prismatic cell manufacturing process at our Livonia, Michigan facility was incorrectly calibrated, causing a misalignment of a certain component in some prismatic cells. This defect was undetected by our standard visual and electrical inspection. When the defective prismatic cells were subsequently compressed as part of the module assembly process, a mechanical interference was created between the misplaced component and the foil pouch which contains the cell. In certain cases, this interference breaches the foil pouch electrical insulation causing an electrical short which can cause premature failure of the battery module or pack, leading to decrease in performance and reduced battery life.
Very clever to spot the potential problem but clamping these particular cells could be a big mistake. Definitely need to figure out a way so that in terms of vibration the pouches, tabs and wires/bus bars are rigidly connected.bigmoose said:I also notice what looks like a piece of high density foam between the last cells and the end caps. What I learned from this is that structural loads into the cells (vib, gravity, etc.) is carried through the endplates against the cell faces. They do not carry any loads from the edges or the tabs. Clearly we should clamp these cells into the cases we (who have bare cells) make for them.
Teh Stork said:Yeah, well - that just adds to my confusion at this point. If it was the clamping and misaligning that was the problem - why are we seeing 'new' cells being sold by themselves, not having been assembled or being dissassembled from packs, on the market?
My *guess* is that the batch of cells that passed through the misaligned torch did *not* all get made into modules. The potentially defective cells were caught in time before going into the modules, so there is a limited supply of cells too.Teh Stork said:Yeah, well - that just adds to my confusion at this point. If it was the clamping and misaligning that was the problem - why are we seeing 'new' cells being sold by themselves, not having been assembled or being dissassembled from packs, on the market?
Agreed. As I posted a couple of times before, my theory is it may be possible to save the *potentially* defective cells by relieving the tensioned bands or the compression pressure that is on the cell stack now inside the modules. Reducing that compression force may actually *prevent* the defective cells from being damaged. IMO. :wink: (Of course, doing that may cause other issues that are problematic too.)MitchJi said:Very clever to spot the potential problem but clamping these particular cells could be a big mistake. Definitely need to figure out a way so that in terms of vibration the pouches, tabs and wires/bus bars are rigidly connected.
MitchJi said:Hi,
Sutho said:mistercrash said:A guestimate on dimensions of the pack? I could fit three in my scooter. hmm...
A slightly more accurate guesstimate on the dimensions would be:
The width and height are dimensions I found in a document. The length is approximated from some known dimensions...
