Here's what I did then. I connected 3 7.2v sticks in parallel for 23.8v battery. I put this in series with 1 12vsla and 15 good ping cells and 4 bad ping cells all in series for around 90v. There is no problem now. It's nice to go 35mph! I got my nimh chargers sorted out. One was kicking off early. I was getting ready to send it back, but I figured I would try unraveling the dc cord (my other 21 cell charger had cord unravelled). Turns out this made all the difference in the world. The charger work fine now. So for my trip, the battery(s) each charge 1.5ah. I haven't tested the capacity again. But I did buy some more nimh battery sticks hi-c to make a new 96v 3.8ah brick. It looks as if I can run 12 sticks, as 6 sticks come out to under 48.5v each, and I don't want to exceed 100v and blow my controller.
The nimh packs run great in parallel, then charge separate. All cells remaining equal. Now when I only used part of my ping cells for first test, Then I have to charge the parts separately. I am always combining different chargers in series to wind up at the proper voltage. But I didn't quite get it with this last separate charge. 10 ping cells charged up to 44v. 5 cells to 24v. oops. I had too much voltage to add all my batteries in series. but I switch off the 12vsla for trip to work, then switch in circuit for ride home. The pings do not lose the extra voltage right away. In fact this extra voltage seems to hang around for at least an ah, or over a mile. Anyhow, the nimh are providing me with battery patch solutions.
There is one important consideration for me for battery choice, and this is about if the single cell is equal to my desired ah capacity. For example, the ping battery is 2 cells in parallel, which breaks one of the rules of .....These type of cells charge equalize in parallel circuit. The discharge behaviour is opposite this, which is opposite to the behaviour of nimh, which discharge equalize in parallel, but must be charge separate.
all in all, I am happy with my 24v nimh, which is 4lbs. I will check the ah capacity again now that batteries have been cycled, the most I have gotten so far is 1.5ah. Voltage at 23.0-23.1 (6cells) after 3 miles, 1.5ah each half of 24v battery.
Check this out. After 1st run, with all cells in series, at end of trip, my voltage at 42v. Then I lift rear tire and apply throttle and brake for load test. The battery meter touched 25v (36cells). But didn't seem to damage battery at all.
