Rix said:
Every once in a while mine does this also. If I leave it plugged in after the fault safety switch shuts off, it still trickle charges. I can't remember for sure, but along time ago, someone commented about this and if I remember correctly, it seems when the charger does this, it actually assists with ensuring the cells stay balanced. Next time you your charger shuts off and its below 87+ volts, leave it plugged in for a few hours, and then check your CA display, I bet it climbs up to 87.4 to 87.6 volts. If I am incorrect, someone please comment.
Rick
I stopped the test after 2 hours. This is what I noticed. It started out showing 86.7 v on the CA. After 45 minutes it climbed to 87.2 v. After 1 hour it was back down to 87 v. After 1 1/2 hour it was 86.9. After 2 hours it was 86.6 v. I stopped the test at this point. I'm pretty sure at no time did the charger cycle back on during the whole 2 hours. The green light was on the whole time too.
Next I pulled the XLR plug out of the bike, and measured it's output at 86.6 v.
This leads me to believe whatever is wrong, if anything, is in the charger. Does 1 volt really matter?
