Ypedal said:gotta keep in mind that the HK graph is a single cell test vs the ebikes.ca full pack + BMS voltage curve !! ( still no comparison to high end lipo.. but yet. )
If you look at Justin's graphs for the individual packs you'll find discharge tests that were done at different current draws according to the specs of the pack.liveforphysics said:Here is some good RC LiPo for a compare:
Notice they start it out at 7C, where these other discharge graphs are 2-2.5C.
A 2C discharge graph for good hobby LiPo has roughly no detectable voltage drop at all. lol
dogman said:Maybe those nicads can put out 5c, for about 10 cycles :lol: I consider them 2.5c at best, after using them at that rate and being a bit dissapointed.
A good part of the appeal of the lipo is that when you cut thier practical use c rate in half, you still have 10-15 c left! Do that with a ping, and you have 1c left.
What I've noticed with my 48V, 10Ah, 5C rated LiFePo packs is that after eight and change the BMS trips when I turn up the wick.dogman said:. . .
Just trying to make the point that a 10 ah 5c rated cell pack does not mean it will last when used at 50 amps till all 10 ah is gone, but you see guys calculating that way all the time.
