Russell
Ecitypower.com and their sister site bmsbattery.com sell a few controllers which sound feature rich (http://cgi.ebay.com/ebaymotors/350W...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories) so I figured what the heck and ordered one from E-city's eBay auction. The price for this 9-FET 36V 350W unit was $20+$24 shipping less $1.60 from Bing.com = $42.40. What interested me most about these controllers was the ability to run with hall sensors or without, an auto cruise function which kicks in after 8 seconds, the PAS connector that I wanted to try and of course the low price. I bought it on Sept. 28 and it arrived yesterday, Oct. 17.
The box got beat up a bit and both flanges were bent a bit.
It's slightly longer than a E-BikeKit controller.
The description on eBay said it was a 14A unit but the rating plate says 22A.
It's sealed with some goop where the wires exit and at the side screws.
Lots of wires but no wiring diagram or instructions were included.
From another post for an E-City controller I thought I had it figured out...for the most part anyway :wink: . From left to right you got your phase power wires, a speed signal (purple), battery power connector, PAS 3-wire connector, 5-wire hall sensor connector, a continuous grey wire loop for which I don't have a clue (EDIT: cruise control) , A standard 3-wire throttle connector, a single brake wire I think but how to use it...?(EDIT: active HIGH) , and finally two white wires which I thought were speed suppressor wires (EDIT: programming wires). The phase wires and power wires were all soldered, a good thing, but I had to cut them off to put on Andersons to match my present configuration.
I mounted the controller on the handlebars of my Raleigh bike in place of a small 36V/15A controller. The bike has a 24V GoldenMotor Mini Motor that I've been running on 36V. I first tried to get the motor to run with just the 3 phase power wires connected but it was a no-go. In two configurations the motor sounded like it was running smooth but the wheel wasn't moving so I assume it was turning backwards, the other 4 combinations produced a hammering affect. I figured it wasn't gonna work so I connected up the hall sensor cable which didn't work properly at first. I ended up swapping the green and yellow wires on both the phase wires and in the hall connector to get it running smoothly. After it was running I did find I could yank the hall cable and it would continue to run, kinda cool I guess, but after cycling power it hammered again.
OK so I figured the thing wouldn't work sensorless , not a huge deal, but then things got a bit confusing. I connected the two white wires together to check what I thought was a speed suppressor function and the wheel started spinning, then it stopped tuning but the motor sounded like it was spinning backwards. The best I can figure is the white wires put it into some sort of program mode where the controller tries different combinations. Instructions would have been really helpful at this point but basically what i did was cycle power and hook up the white wires and when it spun forward slowly but smoothly I disconnected the white wires. After this I found I could run sensorless at all times however it takes a lighter touch on the throttle from a dead stop to prevent the hammering effect. So it does appear that this controller works both with and without hall sensors but it does work better with the sensors. With the hall sensor cable connector I could yank the throttle as fast as I wanted and the motor reacted smoothly.
Now for the COOL part, the auto engaging cruise control. Yep it works as advertised; hold the throttle steady for 8 seconds then let go and the thing just keeps on goin', blip the throttle again and it disengages. 8) Tomorrow I hope to give it a good test out on the road, stay tuned!
-R
-R
