Raged
Cowardlyduck said:Use padding. Lots of padding. And more padding.kiwiev said:what has everyone else done to secure batteries?
As long as your not stressing the batteries and it's not 35C+ ambient, the padding won't cause too much heat build up. You will want to make it easy to remove the cells periodically for maintenance, so it's not a bad idea to enclose the cells/padding all together, but leave the tops exposed for wiring configuration changes.
Cheers
I used gym mat padding you can pick up at Kmart for cheap. It's just compressible rubber that I put on the bottom and jam up top to stop vertical movement ( I don't expect to be hitting anything sideways). I do use duct tape to strap the batteries down to my holders though.
