theGoPedal
We met someone who recently purchased an ELF trike:
His goal is to use it as his primary vehicle for an eco-friendly handyman business. To do this, he will need to haul a trailer loaded with his equipment in and around downtown Kansas City at 20-25 mph. The total vehicle weight is 800 lbs (trailer, 400 lbs; rider, 200 lbs; trike, 150 lbs). The steepest hill he will need to climb is from the city market to downtown on Grand street, a 6% grade.
The trike is currently equipped with a 48v 11ah Li-Ion batttery, what looks like a 12T MAC motor mounted in a mid-drive position and 30A controller.
After a few test runs it is clear that the trike doesn't have enough power to do the job. It will slow to 5mph on the hill and the battery will cut out due to voltage sag if stressed for too long. We'd like to increase the trike's power to make it more useable for the owner.
We plan to increase the battery capacity from 11ah to 30ah by replacing the 48V 11ah battery with two 48V 15ah batteries run in parallel.
We plan to replace the motor and controller with more powerful ones. For the motor, we're looking at this one:
http://www.9continent.com/nkt/products_show.asp?id=119
The main reason is we already have one here in our workshop. We can start testing it right away. But will be powerful enough? Should we be looking at Cromotor or Midmonster? We'd like to model our system on the ebikes.ca simulator but we're not sure how to set up the ELF's mid drive system. We'll continue to investigate this question until we're satisfied that the motor we select will be up to the job.
For the controller, we'll probably go with a Kelly.
Will keep this thread updated with info and pics as the project moves forward.
