I can't find the pin out diagram for the encoder plug, what wire goes to what?New Arrival QSMOTOR QS138 90H V3 with 1:2.35 gear box 4000W Mid Drive Motor
Hello,could you pls provide me more info. about the motor you need to my email alan@siaecosys.com? I will check it for you.Hi! Big fan of your motors. Question, what is the most powerful front wheel fat tire motor you guys can produce?
And is it possible to manufacture a rear wheel motor with a shorter axle that could fit on the front shocks? Something in the realm of 135mm or so I think.
that's pretty much all the info I can provide, 135mm front shock dropout for a 20 inch fat tire bikeHello,could you pls provide me more info. about the motor you need to my email alan@siaecosys.com? I will check it for you.
Anyone has the latest phase to phase resistance/inductance values for the new QS 3000W V3TI 205-50H(3Turn-6Turn) hub motor.
Want to do some performance simulations on ebikes.ca.
Thx.
Try emailing himso qsmotor is on this forum too?nice.question why cant u help a customer?i try to chat with u guys @aliexpress but none of the customer service give me advies or help.should i try here?
Hello,Friend,what can I do for you? If there is any question, pls send me an email alan@siaecosys.com.For the motor issues, could you pls provide me the serial No. on the motor?so qsmotor is on this forum too?nice.question why cant u help a customer?i try to chat with u guys @aliexpress but none of the customer service give me advies or help.should i try here?
Hello,for the same motor, there is no difference between the V3 and V4 axles. For the motor which power higher than 9KW and the phase cable section is larger than 16 mm², the phase wires will go out through the side of the motor. The axles only could allow 16mm² or smaller phase cable come out.What is the difference between the V3 and V4 axles? A lot of the V4 motors I've seen have the phase wires not going through the axle, but through the side of the motor. Are all V4 motors like that?
But this motor is an 8000w motor and it has phase wires going out the side.Hello,for the same motor, there is no difference between the V3 and V4 axles. For the motor which power higher than 9KW and the phase cable section is larger than 16 mm², the phase wires will go out through the side of the motor. The axles only could allow 16mm² or smaller phase cable come out.
the controller I have no longer recognizes my halls even though I tested the halls with a DMM and they all work good. IT strictly runs in sensorless mode only now. I did have to swap my Green and yellow phase wires. I am pretty scared to ride the bike though because sometimes even at high speeds I can feel the cogging/hesitation/sensing feeling. I really don't want a lock up at 40 mph+.The hall sensors shouldn't just fail...so there is probably something that caused the first ones to fail, and now it has probably damaged the other end of the chain (the controller), *or* the problem was a connection issue the first time that was fixed in the process of hall sensor replacement but this time has grown worse (or failed in a different place in the wires or connector).
I need a motor sprocket for QS90 compatible with a #410, #410H or #25h Chain PleaseHello, the sprocket for the QS90 1KW motor is 428 14T sprokect. Is there no sprocket on the motor?
Hello, sorry to inform you that we don't have the sprocket type for 410,410H or 25H Chain.I need a motor sprocket for QS90 compatible with a #410, #410H or #25h Chain Please
those numbers are the chain type/size.
I need a motor sprocket for a regular bicycle chain
You can take the QS sprocket and have the teeth machined off it and have the sprocket you need machined for a press fit and have it welded.I need a motor sprocket for QS90 compatible with a #410, #410H or #25h Chain Please
