Just got my Dashboard.
I just received a volt meter and amp meter from ebay. I need to have a voltmeter on the bike because I don't plan to use a BMS. I'm planning on watching the overall voltage, and simply never letting it drop below 3.0v per cell.
Here are the auctions:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=140176764939&ssPageName=STRK:MEWN:IT&ih=004
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=140177952783&ssPageName=STRK:MEWN:IT&ih=004
I have a question about them: I need to connect a 5v power supply to each of these units to power them. Is there a way to use the 60v battery power? Is there a 5v voltage regulator that will take 60v? If I use a battery (i.e. 9v) with a voltage regulator, do I need to use additional resistors to limit current? If you hook up a 5v battery, would current just flow through this thing and burn it out? In short, how do you power these things?
Also, I've never used those little, white, 5-pin connectors before. I'm assuming that you snip-off each of those little silver pins, then insert a thin wire inbetween the metal tabs. Then bend the tabs over the wire to hold it while you add a tiny dab of solder. Is that right?
Then, I'm guessing that you insert the little metal ends into the connector so that the pins contact the rounded parts of the metal ends? I don't quite know how to describe it. I'd usually just try it except I don't want to ruin them, I don't have replacements.
