punxor, please cross-reference this thread for your answer :
http://endless-sphere.com/forums/viewtopic.php?f=28&t=42644
spinningmagnets said:Found their Ebay store:
http://www.ebay.com/itm/48V-450W-BRUSHLESS-MID-ELECTRIC-MOTORIZED-E-BIKE-CONVERSION-KIT-NEW-CRANK-SET-/190694746581?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D200653249950%26ps%3D63%26clkid%3D1380233566145987562#ht_3787wt_1186
Haste said:those 2 lipos will be 50v full charged.
This setup really requires amps...what will happen is once your in third gear HAULING at 30mph...you will need more amps to get into that higher speed.
Someone confirmed this is a 9ah setup, so putting a little 6fet 20 amp controller should help out ..
Hah, welcome to the internet!Haste said:Love how my thread became a chain related thread lol!
AccidentalBroadcast said:Would this controller be able to handle 66.6v or three of the Zippymax lipo's in series?
Hyena said:Hah, welcome to the internet!Haste said:Love how my thread became a chain related thread lol!
Don't think just because you started a thread means you have any control over the direction it ends up taking :lol:
The stock controller likely has 75v mosfets and 63v caps, so no you can't run 18S (though you could run 15S at a pinch)
But as stated stepping up to a better controller (eg 6 fet 4110) will enable you to safely run 25-30 amps. Safely from a controller point of view anyway, who knows if the motor will take it!
But yes, 12S will still run it fine, and with the stock controller too. If it really is limited to 9 amps then you'll get around half an hours run time from 2 5ah 6S lipo packs in series.
Hyena said:Size, price, availability, what ever
The 8ah are relatively new so I've always used multiples of 5ah. Usually 10ah is a good compromise between weight and range. If I wasnt running parallel packs then yeah I'd go with the 8ahs.
My lasts build has both - 2x5ah and 1x8ah for a total of 18ah capacity.
And yeah, 45v nominal is fine in a 48v system. Just observe the usual lipo discharging rules
The motor can not be mounted on the frame, only on the BB. Maybe this is not the kind of frame you wanna use with this motor. A frame that doesn't have it's BB on the swing arm would fit. This way it wouldn't move.
This is my first attempt at an e-bike conversion. The kit I bought is the 48V 450W mid-mount brushless version. The battery (li-ion) is an aluminum case with battery condion indicator on the back. I'd like to know more about the additional wiring harness connectors from the controller box if anyone can tell me what to attach and what the purpose of it is. The only additional thing I added was an automotive style fuse on the main power to the motor. After blowing 5 and 10 amp fuses, the one in now is 15 amp. It also will blow if I don't pedal hard enough going up hill. The first test ride (15km) went very well.
