mistercrash
Once a week, I balance charge this 20S20P battery I made out of Sony Konion cells. Underneath the shrink wrap, the battery is split into four 5S bricks with positive, negative and balance wires coming up under the seat. I used to charge with two 10S chargers that could take two 5S packs each, that is why I made the battery split in four 5S packs. I would like to use two Hyperion 1420i chargers instead that way I could get rid of a pair of positive and negative wires. I would love to clean up this mess under the seat of my scooter. I'm thinking of some heavy duty 32 pin connectors much like these.
https://www.asi-ez.com/member/~2010322101.asp?Dept_ID=357
https://www.asi-ez.com/member/~2010322201.asp?Dept_ID=357
Or is there something better or cheaper out there?
Also I was thinking of using IDE cables but I wonder if the little wires are big enough to handle the 1420i's. The two chargers are plugged in a power supply I made out of two 12V 47Ah server power supplies from ebay. They're wired in series.
