Wishes
I have recently built 2 12volt 20AH lifepo4 batteries for a mobility scooter of a neighbor. I found some nice 20AH prismatic lifepo4 cells and combined 4 of them with a BMS. The mobility vehicle runs on 24 volts. So we have 2 of them connected in series, combined with a 24 volts lifepo4 charger. The setup has worked flawlessly so far.
I have one difficulty with the setup, the power level indicator that originally came with the mobility vehicle was designed for 2 x 12volt SLA batteries. So with the 4 cell lifepo4, which provides a slightly higher voltage, the power level indicator always reads full.
From what I was able to understand, and recently learned, I should be able to add a resistance to the positive of that meter, to lower the voltage level and get it to work within its proper voltage range.
What I do not know and hoping one of the many experts on this forum can point me in the right direction, is how to calculate the resistance value I need and do I need to put it on the positive, negative, or one on both?
SLA have a typical full charge voltage of around 12.8. As for the lifepo pack is at 14.4 volts on a full charge.
Wishes
Wishes
