Hunza
- Joined
- Aug 14, 2017
- Messages
- 28
Thanks for you reaction docw009. Sorry for my confusing texts, I have the the 48V11.6Ah Bottle-09 Panasonic Battery Pack.docw009 said:Hunza, your first post showed a link to a 48V bottle battery without the integrated controller, and you said you had a 36V controller. You later mentioned a controller bag.
Your last post says you have a 48V bottle battery with an integrated controller. You would expect that to be a 48V unit.
When you overvolt a controller, you should consider the filter capacitors. If they are only rated for 50V like most 36V controllers, they lose their ability to filter at high voltage and will eventually pop. If they are rated for 63V, all should be well. The only way to tell is to look at them as in this pic.
You also need the low voltage protection circuit to match the battery. Dual voltage controllers should do this, but a single voltage controller may let your 48V battery go lower than you want. You still have the battery BMS to protect you though.
I presume the BMSB 48V controller in that package is well prepared for the battery pack connected to that, I will double check that however.
