dougnutz
- Joined
- Oct 27, 2010
- Messages
- 138
This question is probably a little n00b ish but I was curious how many people run torque arms on the rear? I did a little bit of searching already and it seems that 99% of the discussions around TA's are talking about the front. In the few cases where people talk about the rear they are usually using lots of power.
For myself I plan to add TA's to both sides on the rear but at the moment I am just running just one on one side. My dropouts are aluminum but they are pretty thick and the axle has to be tapped into place (tight fit). I'm running a fairly typical 48v setup with current limited to 20 amps. I'm not really happy with my current setup and plan to build some custom arms after I get the disc brakes installed.
I'm really curious what other people have found to be "safe" for the rear. The last thing I want to do is damage the frame.
