Freshair
Seems that hub motors are all the rage right now, and are something I have been pondering about for a while, and now that I am working with cnc equipment for work it is even more practical for me to try some things out.
Stielz hub motor gave me the confidence that the electric motors themselves may be able to take some abuse, and he reckons he has put 300km on his turnigy 6374's. With a motor with better bearings than the turnigy, this may prove to be a very reliable option. Think that his way of doing it can be improved a little, and am still not sold on glueing the urethane to the motor as the only way to secure it. Still pondering some ways to mount it a little more solid, think I may have thought of a way but wont really know tell the motors are in my hands to tinker with.
I already have a set of Rojas Hybrids with round steel hangers, and basically what I want to do is get an alien systems 6374 motor with 10mm shaft, turn 8mm part of the rojas hanger back towards the pivot a little ways and make a 10mm threaded collar for the motor to sit on that will slide over top of the 8mm section of hanger. This collar will be threaded where the nut would normal go on the hanger, so that the collar can be tighten against the hanger. Also, the collar will be threaded all the way threw towards the outside of the hanger so that a set screw can be screwed into the collar as an extra jam to hold the collar from backing off of the hanger.
Have attached a pdf file of a simple sketch up (poor mans cad) drawing that may help as a visual.
Let me know your thoughts.
