crossbreak
yep, but even a 2stroke can have this efficiency... ok not in this package and at this noise level.
liveforphysics said:once you've got a tank of H2, it once again wastes 30-40% of that energy as heat when you try to make electricity with it
more efficient, but loader and more pollutantSounds like if you have natural gas to hand it's better just to burn it in an ICE?
A consumption of 83g/kWh would mean 100% efficiency
?What do you wanna know exactly?? "100% efficiency" simply means there is 1kWh of energy in 83g of gasolinedle, full load or average?
Most steel engines have a thermodynamic limit of 37%. Even when aided with turbochargers and stock efficiency aids, most engines retain an average efficiency of about 18%-20%.
A number of cars these days (not just the Prius) shut off the engine at a stop instead of "idle" which in city traffic really helps efficiency and reduces pollution. More to come, I hope.I assumed the 18-20% average efficiency represented "normal" use. I.e. 40% peak efficiency, 0% when idling, and everything inbetween.
