Here are the assumptions, real life I might add:
1. Difficult to drive low turn count motor where most riding is in current limiting (I assume the point of max power or 1/2 the no-load speed is where LFP's red line resides, and if it's not there, it's very close), where the cutoff is 37mph at this voltage.
2. Identical battery and voltage.
3. 2 different current limit settings via shunt modification so the ratio of battery and phase current limits have a constant ratio using the same controller.
4. Very low speed riding, where very low duty can still result in failure from narrow spikes in phase currents due to accidental repetitive small pulses of the throttle, though important, is not a topic of this post.
5. Acceleration and speed are identical. With the lower current limit, acceleration is generally WOT up to 30mph, and with the modified shunt an equal acceleration is accomplished through moderation of the throttle. Throttle position at cruise is identical, since speed is the same and neither current setting results in max speed = cruising speed.
My question is, will the heating of the FETs be identical along with efficiency and the PWM. I believe the answer is yes, since I just modified a controller for active air cooling, but I took the shunt modification farther than I have before with the same controller. If I'm hard on the throttle, then I get significantly more performance, but the controller gets failure range scorching hot without the fan turned on. However, just by going easy on the throttle during acceleration with equal cruising speed, the controller stays just warm to the touch.
Now the big issue, hills. I've got regular hills that I cruised up at WOT many many times without issue with the lower limit controller. The speed was right around the current limit cutoff, so I was at or very near full duty. How should I approach the same hill? Higher speed will require higher power and higher battery current, but if I try to go the same speed as before, then I think I'll be at partial throttle and chopping the current via PWM at high load could put the controller at risk. I believe the right answer is WOT is better on hills, period, and I may have an identical top speed anyway unless I was actually in current limiting before. That means with active cooling of the controller and WOT there should be no way the same hill kills an identical controller unless I add enough extra load to push me back into the rpm range of current limiting.
Did I pass the test?
