Right
Got busy tonight...popped in to my local Maplins and picked up a nice little plastic box big enough for the board and the socket, its about the ideal size, I cut the socket hole out for the D connector and slotted the board in, it all went together really well!! I hooked it up outside and tested it by selecting normally closed from the alarm output and each opto channel switched perfectly, I will video this in action on the bike tomorrow with it hooked up directly to the controller.
I am really pleased with the way that this has come out, I can ride with a bit more piece of mind although I wont be complacent about it!! the hardest part about the whole job was linking the wires and sleeving them on the back of the D plug, I checked and double checked it afterwards with my meter.
Now time to play with the cellog to make sure I am happy with the default settings, they look nice and easy to use, I think that out of the box they are set a little over sensitive, I will have a play and make sure that it is set up to match my pack.
The 2 core white wire is the brake inhibit connection to the xlyte controller, will post a video to show that working.
Right some pictures, this took a lot longer than I thought it would so respect to everyone on here that has had a go themselves!!
Knoxie
