Blueshift
My Ping battery is dying on me. Well it has slowly been dying. I cant take the battery apart or put the meter leads on the bms because i have a visual impairment and chances are that I would shock myself or cause more damage to the battery.
The Only thing I could do would be to check the voltage of the charger as the pins are bigger and only 3 of them. it is a 1a charge the default one that came with the battery. it has 3 prongs. Where do i put the leads from the voltmeter onto the charger.... the end has 3 prongs... kinda like an xlr cable for a microphone. One of the pins is lined up with the top part that snaps in to secure connection with the other end.
O
O O
A little bit about my battery use. I have ran it dry 3 times altogether over the 4 years Ive had it. I usually leave 20-40 percent charge in the battery. By ran it dry I mean where it shuts off. I suppose the BMS could shut it all off if one of the cells was dangerously low?
Anyways, my only option is to hope its a bad charger at this point. I guess it might be to late, but its worth a shot i guess.
O
O O
