dimpirate
Im building Lipo pack with 16x turnigy 6S 5Ah batterries http://www.hobbyking.com/hobbyking/..._5000mAh_6S_20C_Lipo_Pack_USA_Warehouse_.html
for a 24S 4P 88V 20Ah
I want to charge my whole pack at once here is the charging method I would like to use.
4 x HVC + LVC + Parallel Boards (Cell Level Protection) from meth-tek.com http://endless-sphere.com/forums/viewtopic.php?f=31&t=32460&hilit=methods+methtek
1200W Battery charger http://www.bmsbattery.com/alloy-she...ifepo4li-ionlead-acid-battery-ev-charger.html
and a cheap balancer for periodic balancing http://www.hobbyking.com/hobbyking/store/__5606__Genuine_IMAX_B8_Charger_Discharger_1_8_Cells.html
This also would make charging out of the house easier (lighter) which is a big plus.
Is this safe, will it work?will i need any connectors (to connect to charger) besides what is provided by methods parallel boards?
Is this a good alternative to buying an expensive charger/balancer (hypernion, icharge) or meanwell power supply?
I plan on using Methods parallel boards which ever charging solution I end up using.
Ive looked thru many lipo,and lipo charging threads, the information is all over and definately hard for a noob like me to keep up with, specially when it comes to bulk charging. Id appreciate any info, tips, links to threads you guys might have. It would also be nice to have a thread dedicated to bulk charging(I assume there is havent found it yet :? ) where the best most reliable charging methods and where to buy are listed.
Thanks for any help
Fred
Thanks for any help
Fred
