okp said:great job ! don't worry for the rough surface; just sand it with 180/240 and once you are happy; apply standard epoxy resin (no gel coat or whatsoever) that you hot with an hairdryer. this will work fine and make this a mirror. if you want a matte finish, just use a spray can varnish from a graffiti shop.
whitepony said:basically thats what I did, but then lots of small air bubbles came up. :/
randyc1 said:Hi Whitepony, Concerning your GT3 Belt,...I had called Gates Company about these belts ,and was informed these Belts are indeed superior to HTD,... BUT only when used with Gears above 18Teeth i think, had to do with the (GT3 Bend limits), I was told anything under 18T, HTD was better.
piyiotisk said:The single vs the dual drive when you accelerate or brake is there much torque steer on the single?
