neithermovingnorstill
Update: Turns out this won't work, as Gray Kard pointed out, the quad has single sided hubs, so hub motors won't work because they need support on both sides. I'll either have to run mid-drive, or choose another steed.
Hi,
I'm still investigating the possibility of E-converting a quatrike. I want to put the motors up front for various reasons.
Unfortunately, it has 16" wheels up front, so RPMs and winding become an issue, if I want to go over 15mph.
(15mph on 16" wheel= 310RPM)
Ideally, I'd use something small and light (XMUS, Bafang, Cute etc) but they are all about 310RPM or less as far as I can tell.
So I'm wondering: Which small geared hub motor has the highest RPM/lowest wind?
Yes, I realize that small wheels makes hub motors run cooler (allowing more wattage), and using two means they split the amps (run cooler), and higher voltage means lower amps/heat, so I could push them pretty hard...
but I want to be as efficient as possible, and since the small wheels / dual motor setup both cause an increase in torque, I think I should go with the lowest winding available.
Hi,
