El_Steak
Methods, any idea how much current goes through that little switch? Is it completely separate from the current pulled from the batteries?
Oh yeh its even labled fuse lolmethods said:Arlo1 said:Fuse?methods said:P.S> Put the fuse external where you can get to it :wink:
Look at his picture. He installed a Fuse.
-methods
El_Steak said:Methods, any idea how much current goes through that little switch? Is it completely separate from the current pulled from the batteries?
chxs said:Hi methods ! I just finished to translate the new Chienne programmer so ... i need one can test it ! i dont have my programming cable yet ! So ... This is a screenshot of what they look like ! This is the First Release ! I'm sorry for limition on Text ... ( Y = yes ) I have to respect a number of letter if i dont want to corrrupt the progs ! so now PM me if ur interessed to test it ! Tanks
hi DocDoctorbass said:I dont know if it already existed on older programing software versions but the CHXS version have the Phase current value up to 370A and the rated ( batterie) current to 100A.. not just 57A like in the past version.
It work well for me...
Very nide work CHXS..!!! :wink: eventhough you dont wear an helmet at 80kmp on ebike and twisted your X5 axel by using only one torque arm with 15-20kW setup,,,,,.. you appear to have a brain anyway
Very curious.. no immediate need to beef the shunt like before !!!!
.. just reprogram it... ( and ensure the shunt dont overheat!!)
Doc
geoff57 said:hi DocDoctorbass said:I dont know if it already existed on older programing software versions but the CHXS version have the Phase current value up to 370A and the rated ( batterie) current to 100A.. not just 57A like in the past version.
Doc
just had a search on ES for the software but can't find it can you post it or can CHXS post it all I have is the latest version but with the 57A limmit.
Geoff
