John,
Ok no problem, never considered the MiniMonster. It sure has its advantages but considering I want to occasionally ride with madame I'm thinking that it would suffer from the total weight and hills. I'm a bit of "big block" guy don't tickle me too much on the HubMonster :lol: Plus it will already be a challenge to put the Mid Monster in a optimal mid mount position (yes i've really been thinking of putting the Hub Monster in mid mount too, Custom bobber look-a-like). I'm figuring the proper dimensions, at least with the diameter from both hubs I can arrange the frame. More adaptation needed since these motors are outrunners, I'll solve this anyway.
I'm trying to maintain a low weight limit around 60kg, more easy to say than to do, a motorcycle fork can weight around 8Kg, torque arms can weight between 5-8, considering I will carry more batteries than I was thinking it can also count its toll (thanks to Lipos it's not too much of heavy stuff). Controllers usually don't exceed 4kg each if I recall. The frame itself bare thick alu I'm estimating 15kg for the moment, maybe I'm over estimating. Leather seats will bring some weight too. What worries me are the rims and brakes weight, I finally found tyres worth the look and performance : Avon Cobra! Match it with a bobber like set of rims and it's killer look with good wear thread and grip for high speed and corners.
By the way was I correct with my layout logic or did I put too much batteries? I.E. just align batteries for the desired voltage, then instead of parallelling the total line, just add the batteries required for amperage? Hard to write, easier to show, example :
-6s-
-6s-
-6s + 6s|6s|6s-
-6s-
-6s-
or it must be a full
-6s|6s|6s|6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
I know that just adding batteries in parallel raise amperage, series them raise voltage. Wondering if I'm over calculating by paralleling the totality of batteries.
-6s-
-6s-
-6s + 6s|6s|6s-
-6s-
-6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
-6s|6s|6s|6s-
