Motor weak power
dogman dan said:
I have a suspicion that your problem is quite simple. Your new controller is defective.
But before you complain to the vendor, do what you can to see if you can change any settings on the display. You might be just stuck in power level one or something, because they sent you a display that reverts to level one each time it powers up.
Actually my problem is solved with the intelligent wires set-up. Thank you for your suggestion.
seba240698 said:
I see that you have exactly the same LCD as I have. I had the speedometer shown in your photo ordered online too. Is the speedometer good? Does it come with backlight?
That particular bike computer is a wired one. The others I have are wireless, and they sometimes don't work when the battery gets low. With a wire, I only need one battery. These meters take your wheel circumference to the nearest cm, so I think they're better than the controller/LCD which takes diameter 20 in, 26 in, etc. SOme are backlit. This one is not.
