cwah
Hello there,
I'm thinking about having the possibility to easy change the voltage of my battery. I've for now 4 * 18.5V8AH zippy lipo:
I'd like to have plugs allowing me to swap between 72V8AH to 37V16AH. For now gluing HXT connectors together for that but they are difficult to manage.
I've found these:
http://www.ebay.co.uk/itm/10pcs-8-Pin-Male-Female-Wire-Panel-Connector-GX16-8-/150623087535?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2311d5ebaf#ht_1519wt_1114
I have for now a 30 amps controller so it won't be huge. I suppose I should plan for 80 amps for future needs.
If I'm using 80 amps, because I have 8 plugs the amps would be divided by 8 isn't it?
So I'd need around 10 amps plugs and I suppose most tiny plug (and of course this one) should be enough for the current?
Thanks a lot
I've found these:
Thanks a lot
