dmccart4
- Joined
- Sep 6, 2008
- Messages
- 18
I just wanted to say thanks to everyone at Endless-sphere for all their help and advice with putting my Ebike together. My set up is,
36V20Ah Headway battery discharge - 60A continuous, 80A peak
5303 rear hub motor crystalyte
36v 20a controller crystalyte
Controller Problem
I was going up a hill the motor just stopped. The controller switch light flashes once when I turn it on and I've checked the battery using a multimeter and its fine. I've used it for about 30 miles.
I found this on ebikes http://www.ebikes.ca/troubleshooting.shtml
14.Fried controller mosfets
When controllers fail and you see a puff of smoke it is almost guaranteed to be a blown mosfet. There are two things which usually cause a mosfet to blow, #1 is too much voltage, and #2 is too much current. Unless you connect say 72V battery to a 36V-rated controller (usually has 55V rated mosfets), then it is almost certainly too much current that caused the damage. This will happen very predictably when smaller controllers are used with motors that have low winding resistance, say using a 36V 20A controller with a 5303 hub motor
Do I need to buy a more powerfull controller, fix the switch in the controller I have or something else?
Controller Problem
