Randomly said:
I'll give you the discharge protection on the CD4538 if you are using the Fairchild part. However this is not true of 4538 of all manufacturers, TI for one requires protection.
Sure theoretically the 4538 would operate with any length pulse widths. However you have to deal with real world components. Please go look up what the worst case leakage of your 1000uF cap is. My point was the leakage of the cap can far exceed the pullup current available from the resistor and the circuit will never reach the trip point.
I'm not arguing about the current drain of the LVC circuit before the pack hits the cutoff. It's almost irrelevant, even a few milliamps with a 10,000 mah pack lasts a long time. However the current drain after the pack hits LVC cutoff is crucially important and that is where you increase the drain to about 1.5ma.
so if the drain goes up to a couple of ma that means that in about 3 weeks you will lose 1 Ah. what actually happens is that as soon as the load is removed the battery voltage rises, so the LVC is negated and the drain returns to microamps. My tests have shown that there is about 10% capacity typically remaining when the LVC trips, so yes i do not recommend letting the battery sit in the discharged condition for weeks.
you are absolutely incorrect that there is only 1% of the capacity left in a 10 Ah pack after the first time a cell hits 2.1v (or 2.7v for a123). as i have stated it is at least 10x that. you are ignoring the voltage drop due to the battery internal impedance that causes the voltage to dip to 2.1v while at 30A and .005 ohms is actually 2.25v cell voltage
Randomly said:
When the LVC trip point is hit, you no longer have a huge AH capacity battery, the battery capacity is now relatively tiny.
Go look at the discharge curves on a 10AH cell and tell me how many mah of capacity are left in the cell after it hits the 2.1V cutoff? Maybe as little as 50-100mah. The curve at that point is extremely steep. How many hours at 1.5ma will it take till the voltage falls to the point where the LVC stops working and reconnects the load? It may only be a couple days. Don't forget the R4 load which never goes away, which will be about 500uA with a 16cell pack.
i have looked at the curves, and i am aware of the self discharge characteristics. if you think a half a milliamp is too much disconnect the bms when you are going to let your dead battery sit on the shelf. i always charge mine asap.
Randomly said:
You misunderstand my objection to your 6.2V zener as gate protection. Certainly it will protect the gate oxide from punch through. My point was that the 6.2V gives too low a gate voltage. The worst case Vgs threshold is 4v, this increases with decreasing temperature. A 6.2V gate drive is so close to this that at high currents the channel may start to pinch off putting the FET in the linear region.
here once again you are not really looking at the numbers or considering the function. the irfb4110 will be operated in the linear mode during the reduced charge current phase, and is driven up above 4.5v when full on, and that is plenty of voltage to turn on the fet completely under all forseen conditions.
i knew that when i posted the schematic it was likely there would be people who wanted to pick it apart. go for it. i dont have time to argue any more irrelevant issues.
Randomly said:
I'm sorry if I come across to you as sarcastic and are taking these comments harshly. It's easy to misread intent and meaning in purely text based communication. Every one of these points I've raised is valid, please consider them carefully and I hope they will help you. I'm not interested in designing a BMS to sell, and I only spent an hour or so going over your schematic out of interest.
i did not mean to be harsh, i just dont have time to argue engineering with every newcomer. if you dont like the design dont buy one. i am really beginning to doubt that selling them can be profitable anyway, so you may never get the chance. i did not set out to design a product for sale. i just needed one bms for a lifebatt pack i sold (the only one) and lifebatt did not come through. I did not spend as much time as i should have for a production design, but when i only have the stamina to work an hour or two a day this is what we get. I have a steady stream of controllers to repair that i can make about $25 an hour at, so forgive me if i focus on that and dont have time to argue about operation of components outside the design parameters.
some of your points may be valid, but you will get a much better response if you avoid phrases like "what were you thinking?" and maybe replacing them with "it might be better to...". Certainly there is leakage in the electrolytic caps but it is not high enough that it does more than extend the time past the predicted RC value, and the timing was only meant to be approximate anyway. most likely the charger will just be cut off as soon as all the cells reach the shunt voltage and the one shot will go away. the long time delay was only intended to give the user time to disconnect the charger before it restarts and initiates a short charge cycle. it could be replaced with a latch and reset mechanism. i have been using the 4110s for quite some time and have had no problems with driving the gates to 5-6v and expecting them to handle all the current i need. i will take a look at the consequences of driving the gate voltage higher to the other parts of the circuit, it is a good suggestion just to guarantee performance over a wide range of temperature and current.
