paulbram
10 µW
0utrider said:paulbram said:when I approached a fairly long hill at which point the battery went down very quickly, started flashing, then finally everything just shut off.
Heat shutdown? Were you in an easy gear for the motor to go up the long hill? I'll assume your battery pack's cells are balanced.
Speaking of which, how much difference between individual cells is considered out of balance?
It does seem odd that the charger is showing a full capacity regardless of your usage.
Ok... I think I figured out my problem. I just took a closer look at my charger and it was set to 220 volts!!!
Yeah... once I switched it to 110 now the LED's are red and it's charging nicely!
Rookie mistake. First of many I'm sure!
