Russell
mushymelon said:Its a single up front so as long as your within the chain wrap capacity of your derailleur a short cage works just fine. Chain will be tighter too.
The "capacity" of a particular derailer model is the largest range of sprocket sizes it can handle:
36t - 11t = 25t chain wrap capacity and up and your good.
Manufacturers have to assume that their customers are clueless, and will expect the chain to have some tension on it even in the bad gears where the chain is using small chainrings with small rear sprockets. Thus, the rated chain-wrap capacity is very conservative. A competent cyclist who uses the gears properly can generally exceed this by several teeth with no problem.
Most derailleurs also specify a maximum size rear sprocket. This is often a pessimistic value, based on the largest sprocket that is normally provided as part of that group.
When you rip-off text from another site you should give them credit
http://sheldonbrown.com/harris/derailers-rear.html
The largest rear cog I've ever been able to get to work with a short (road) rear derailleur is 30T, and that was with the "B-screw" cranked all the way in. For more than 30T you do need a mid or long cage rear derailleur.
-R
