Jeremy and Luke, You are totally right. I compare with my impression about the feeling on the ebike and not with math and physics law and that could create some confusion between the real theory of torque.
Torque = phase current x winding turns
The magnetic flux intensity in the stator is proportional to that = torque.. allright
I called that electric transmission because the feeling i had when i switched from WYE to delta was like ta kickdown and acceleration reborn suddenly.
I really feel 2nd acceleration kick when i switch to delta. And i am under the impression that since the motor approach the back emf close to the battery voltage, current decrease and acceleration decrease.
When i flip the switch to delta, the back emf of the motor scale down of 1.7 factor and the battery voltage is still way higher so there is more current and more power.
The way you talk about torque relationship would make us to believe that this is like unusefull to choose a motor with low KV since we can get same torque with a high KV but the high KV (like the HS) give more speed.
So choosing the HT would be like choosing a limited speed motor instead of full speed HS range motor.
So why they still call HT or high TORQUE and HS for high SPEED... :| ?
Above 50% of the speed range the power decrease so switching to DELTA realy help for the acceleration rest of the speed range think. True .. False?
Since the efficiency of the motor is p^rogressive with RPM, choosing a High KV motor mean that unless you drive it WOT you will make it less efficient and generate more heat...
So if you want powerband, toruqe and efficiency, a normal motor can not give you that... but the Delta WYE can help since depending on the speed you run your ebike, you can choose the KV you want with the switch of delta wye and be closer to the best efficiency...noh?
Now i would better call that VARIABLE KV BRUSHLESS MOTOR ADAPTOR...
Btw.. i was looking at the simulator page of ebikes.ca and he added a new motor, the N3505 and N3507 ??
hmmm....3505 for HS35 and 3507 for HT35?
http://www.ebikes.ca/simulator/
Doc
