latecurtis
As the Hub Motor Turns and the LiPo Fire Burns. bum wheel.
I went thru the trouble of reinstalling the motor on the 24" cargo bike again for a third time this week and it was for nothing. This time I drilled the holes in the brackets farther apart then before for more room for adjustment left and right without the bolts hitting against the frame. It looked as it was perfect but after several rotations the chain popped off. Further inspection and I found that the wheel bearings are shot and I suspect that some of the bolts in the spoke sprocket may be loose.
The wheel and sprocket are total pieces of shit and my motor mounting skills are not the cause of this calamity. I also have 100% proof of this in the rear Currie wheel which I went to Home Depot with yesterday. I spent $120 for the straight perfect wheel which spins perfect and the chain is still as tight as it was when I mounted it. Not too tight however but perfect. My home made brackets work and mounting skills are exceptional.
I do not know what I will do next. however am thinking about scraping the 24" cargo bike. If there was a 100 foot cliff nearby I would throw it over. I should not feel that way as the wheel was used anyway and two years ago when I first built it I took several videos. It could just be basic wear and tear on the wheel. That wheel went 29 mph not too long ago and up Congress st. hill when I smoked the alligator clips.
The thing now is do I have a good enough wheel to even bother transferring the 60 tooth spoke sprocket to ? If not do I want to buy a brand new one. That would be a NO absolutely not. I spent enough $$$ on e bikes. I got bills to pay and a limited income. Also installing a spoke sprocket even on a good wheel is a pain in the a s s. It requires a lot of adjusting to get it to spin good enough to keep the chain on. Several hours at least and I am sick and tired of getting my hands dirty. All that black grease don't wash off and takes several days for clean hands again. Everything I touch has black marks on it.
https://www.youtube.com/watch?v=iEqzPOZncDU&feature=youtu.be
The fix
https://www.youtube.com/watch?v=RDiKyA8ATr4&feature=youtu.be
When not using a derailleur the freewheel will work better for a pedal chain. Hopefully it will stay on if I can get it tight enough. I am going to Wall-Mart to get some soap that has the sand like stuff in it like the auto mechanics use. Hopefully I will have enough ambition at some point in time to switch the 60 tooth spoke sprocket. No more clackety clack if I get it done. Thing is though I am lazy. Thanks.
LC out.
I hired a kid to change the sprocket to the other wheel for $10. The kid is 15 with no job and school is out so it should help him out. Hopefully it will be done tonight or tomorrow. It will also give him experience turning a wrench. I am trying to give him things positive to do to keep him out of trouble.
Also just got off the phone with Johnny who wanted the Schwinn and I told him I will give him the Cleer Creek Schwinn but he needs a rear motor as he plans on using the bike for dirt trails and mud and I said he needs to order a rear hub motor as the front motor will spin out on him and he could get hurt.
The front motor Sunder sent I will put on the front of the Haro V3 with the best torque arms I can find and then a 1,500 watt 48 volt hub motor will go on the back. I will use a 60 volt brush less 80 to 100 amp controller and build a custom battery pack for it. Total power will = 1,875W - rear + 1,250W front = 3,125 watts.
Can someone please let me know if it will work with a single thumb throttle. Also tell me how many of these I will need and how you think it will work.
https://www.youtube.com/watch?v=9Pxq4Au5iuc#t=3.225358
http://vruzend.com/
I have never attempted anything like this. Also I do not want to go much past 60 volts as to NOT damage either 48 volt hub motor. I know that fully charged the voltage is much higher than when run for awhile so I do not want the total voltage fully charged to exceed 60 volts by a lot but also do not want a low LVC cuttoff to happen either so I need to know the exact specifications and also the BMS and 60 volt charger I will need. Please let me know.
https://www.youtube.com/watch?v=AYDF1Q9vaGM
I know I have been warned about high power front hub motors but the 60 volts is only 250 watts more than the 48 volts I am used to for a front motor and also it is not something that has never been done as this video shows. There are also many more dual hub motor videos on youtube.
This will be my last e bike build ever. The other e bikes I am simply maintaining . The only future build after this dual hub motor Haro will be the FX project which will require a beefed up 125 cc dirt bike frame or a build almost like the original Death bike. That could take up to five years with my limited budget but will be saving up for it once I finish the Haro V3. Thanks and please post when you can.
LC out.
The fix
LC out.
http://vruzend.com/
LC out.
