comradegerry
I am stuck at the tail end of my build. Everything is connected as you would expect, 48v battery connected to 12 FET LYEN Controller, controller connected to a 10 turn Astro 3210 with Matts cool reduction drive, 1/2 twist throttle connected to Motor.
I disconnected the CA to rule that out as a problem, so with that out of the equation the following happen when I turn the throttle.
The motor barely turns over, in the right directon, with the wheel off the floor, so minimal load it creeps up in speed and then faulters, motor was drawing 6 volts max when it stalls. Batteries have just over 50v in them. I tried all 6 of the wire combinations between the controller and the motor, same result, 3 spin forward slowly, 3 spin backwards slowly.
My Astro is sensorless and it is a sensorless controller, I had hoped they would talk to each other but I may be wrong? I have heard of synch issues but did not expect them at no load. I planned to set a 4 mph speed minimum through the CA to solve the start up issues as I had seen someone else on here do.
I am also planning to add Burtie's optical sensor soon, even if I can get it working without.
Any ideas on what to check or do? I did have a short the first time I plugged the battery in due to putting the plastic polarity cap on the wrong way, they are only fool proof if you assemble them correctly the first time Could that have blown something in the controller? It was just a brief but large spark!
I would buy a new controller today if I knew it would work but I do not want to throw good money after bad if I am barking up the wrong tree. I would have gone down the CC HV 160 route but at over 50 volts hot of the charger the battery would kill it.
Any guidance would be greatly appreciated. Attached is a photo of the almost working bike.
