Synon
I'm in the process of building an 18650 battery pack for my 48v 1000w hub motor. The batteries are used laptop batteries, I've tested them all and I'm working on the final configuration of the pack. I built a triangle that can fit a max of 185 batteries so my question is this... I can either build a 12s15p (180 cells) pack or a 13s14p (182 cells) pack. Maybe I'm splitting hairs here, but am I correct in that this is simply a trade off in power vs. range? I have a 13s charger so that is not an issue. Would the 12s15p configuration be slightly gentler on the batteries since they are not designed for high discharge? Anything else I need to consider?
