QSMOTOR,0.5-12kW Electric Hub Motor & Mid Drive Motor Manufacture China
Aliexpress has stuff that doesn't appear to have ISO specs in various multi-sprocket thread-on freewheels. It takes quite a while to look thru the stuff because their search REALLY sucks, so you usually have to use a google search of their site to find things, often by reverse-image searches rather than text (because words are often misspelled or completely wrong ones are used for what something actually is, etc).
But it might be worth looking, if you really need one--just make sure that the specs provided for a given freewheel are what it actually is, and that this matches what you have on your hub.
(I just spent a lot of time, the last several days, trying to find an ISO 18T singlespeed freewheel with reliably given actual ISO specs, *and* splines or slots for common removal tools (most of them dont' have any way to remove it other than disassembling it, which is ridiculous because it doesn't take much to add (to the design) the metal ring to host the slots and then add the slots (simple enough manufacturing processes compared to the rest of making the whole part)).
BTW--since ISO thread-on freewheels/hubs are sized and threaded the same as the same diameter BB (bottom bracket) parts, you can use the one part to test fit and verify dimensions of the other, if you don't happen to have the proper part to mate with it and need to know what it is to go buy that part.
thanks for the info, havent been able to find a 7Speed qs205 or qs273
but these guys claim they have them avaliable QS 273 V3 Ebike WP40H 72V 8000-12000W
also enduroebikes.ca confirmed they have QS205 with 7-speed but limited to QS205 and not to QS273 becasue of size.
QS120 60H 2000W Mid Drive Motor V3 with Gearbox suitable for electric motorcycle and scooter. If there is any interest in it, pls feel free to contact me.
Which one is the strongest hub motor for a 135mm dropout?
"Strongest" will depend on your specific purpose and riding conditions, and required power and torque levels, etc
@QSMOTOR: I want to buy a 6 turn(7.29kv) Qs205-3Kw hub motor. What are the differences between the 6-Turn QS 205-3000W@48V/72V and 96V.
If anyone knows the answer. The knowledge would be much appreciated,
Thx.
@AdR The 6T (7.29kv) for QS205 3000W V3 spoke motor is available. For 6T winding, the RPM is 340RPM@48v, 510RPM@72V and 680RPM@96V. Here below pls find the performance report of 6T QS205 V3 hub motor for your ref. The voltage is 72V,70A DC current. And the max. torque is 164 N.m and the max. RPM is 563.8 RPM.
Any further question you have pls contact me email or message.
@peadar The pole pairs of 8KW motorcycle hub motor V4 is 16. Usually for QS hub motors V3 and V4 versions, the pole pairs are all 16.
Hi Alan,
I think QS sell Fardriver controllers, I have some questions relating to setup and wonder if you could assist?
@QSMOTOR Do you have anything currently that will fit a fat bike with a 170mm or 190mm dropout?
Hello, for 170mm dropout, I suggest to add spacer to make our 150mm dropout to reach 170mm dropout.
for 190mm dropout, I suggest to add spacer to make our 150mm or 175mm dropout to reach 190mm dropout. The standard of QS205 spoke motor is 150mm or 175mm dropout. See below two drawings of 150mm and 175mm dropout for your ref.
150mm dropout
175mm dropout
Hi Alan,
Hello,yes, SiAECOSYS&QSMOTOR also sell FarDriver controller. Would you pls advise if the FarDriver controller sold from us? Would you pls provide the product label and questions to my email alan@siaecosys.com?
150mm dropout
175mm dropout
Thank you for the reply, what is the best way to talk to somebody about buying this motor? I sent an email to your address but have not yet seen a reply. Also, is the QS 260 also available with a 175mm dropout?
Hello,I got your email. Will reply you soon.
Hi! I was wondering about turns and strands in the QS180 90H motor winding and also about pole pairs count, can you clarify that? Also, is there any possibility of having that same motor in a water cooled version? Hope to hear from you soon!
