Philistine
- Joined
- Aug 15, 2010
- Messages
- 1,736
This is a question for the lipo gurus. My question is this, if you took two lipo batteries, and you discharged one to 50% of its rated AH used, then recharged, and did this 100 times. And you took another battery, and discharged it to 25% of rated AH used, and recharged, and did this 200 times, would there be a noticable difference in the lifespan/health of the two batteries, and if so which is better, and how much difference would there be? (if the 100/200 is too short a span to see a difference then insert whatever would be a substantive period)
The basis of my question is, that on my Yuba I have a 40AH pack, and although sometimes I use the available extent of the pack when I do big cross city rides without charging, most of the time I can choose when I recharge, and because I like having the highest voltage possible, I tend to recharge as often as is practicable. I was wondering if repeated short depth charging drastically shortens battery life (ie, if I am constantly recharging with only 25% of battery used, is that shortening the life span much compared to recharging less, but going deeper. One reason I also like charging frequently (ie as soon as is practical to recharge) is that it also keeps the cells more balanced (going as shallow as possible). But it got me thinking about lifespan.
What is the thoughts of the gurus?
I doubt the answer will change my behaviour, as in the year and a half I have been running my packs I have seen very little performance loss (other than packs I have blown up or damaged myself), but I was interested from a theoretical perspective as well, ie what is it that wears down a battery, AH extracted from a pack over time, or the rate of charging?
