Thanks all. This is bike that I have dreamed of last 5 or more years. I had a vision what it should do but not a clue how to do it.
It is 100% ES forums inspired bike. Maybe some frame design is from other side of the web world.
I will try to explain the idea. The frame geometry is from my dh frame building experience in last 150 years. I have made 9 fully DH frames, Unfortunately (for you
) they are all sold together with intellectual property so I can't show you any design.
Travel will be 200mm front and 265 mm rear. Rear travel trajectory is almost parallel to front, maximal wheel axis distance growth is less then 3mm on full stroke.
To do that swinarm will be 935mm long and swing arm pivot axle will be 150 mm from head tube. There are two rear shocks connected parallel from swing arm to head tube.
On head tube is mounted some type of rocker arm so you can adjust rear travel/force curve with 3 inflexion points just by making different air pressure in shocks.
Second part is unsprung mass. It will be low,
you can see the first picture it is fixie. Drive is true ES baby, It was inspired by Phaser-Matt-Miles cluster of ideas... on second picture the axels are ordered as on bike. Right axle is output/swing arm-pivot axle, also there is first freewheel to reduce resistance when bike is cruising,
There are 4 parts that are connected coaxially, only output sprocket and disc are connected together, the outside bearings is swing arm bearings, the middle axle is "collector" . on bigger freewheel is motor input and next to him ,smaller freewheel is crank input, sprocket cluster is part of the gear box it has also freewheel .
The shifting mechanism will remain secret for now
. The frame and the swing arm will be made out of 20mmX1,5mm CroMo steel tubes, with as much as possible bends...
There are plenty of room for improvement but I have decided to build it now as it is, with all its mistakes. When it is finished ,build another, improved,
