I've got a Max-E pushing a QS205 50H 4t and have noticed some strange behavior lately.
Last week I pointed the bike up a steep hill, nailed the throttle, and around half way up limiting started kicking in. When I checked motor temps were well within range but the fet temps had climbed towards overheating. Pulled over and off throttle the temps quickly dropped from 70 to 40 but as soon as I leaned on the throttle again the fet temps quickly shot back up.
Since then this seems to have become a more common occurrence, and it doesn't necessarily have to be uphill. Riding around town on reasonably flat ground the fet temps will suddenly decide to climb and after that point any real throttle input will have them shooting from 40 towards 70. Even throwing it into eco mode with battery and phase amps set low enough to walk beside it at WOT doesn't stop this behavior at that point, but if I keep my throttle inputs to a minimum it seems that I can continue to limp it along.
It doesn't seem to be a progressive type of thing either, or at least not linear. That is to say it'll slowly warm from 30-40 but once this starts happening it's an extremely rapid rise from 40 to 70 even under very little load, then immediately back down to 40 again off throttle.
The controller IS mounted inside the frame, but it was in there during the summer as well without this being an issue so I'm not sure if that's directly related. Hadn't recently made any changes within the Adaptto that could account for this, however I did change a flat not too long before this happened. Positive the wires are all in the same orientation when it went back together, but not positive there isn't some unseen insulation damage hidden somewhere. Motor is running quiet and cool, but wondering if emf leakage could account for this or what?
